Perfect Pizza Cutter - Does it Exist??
  • nissanneill
    • Apr 2007
    • 1886
    #16
    Re: Perfect Pizza Cutter - Does it Exist??
    Jay,
    sorry I didn't reply earlier!
    Yes I make all things myself, as you often have trouble finding them let alone justifying their costs.
    This cutter was an offcut from my stainless chimney funnel void so decided to grind the cutting edges using the sides of my 8" bench grinder (but don't get the edges hot and burnt as you change the crystalline structure of the metal and often soften them). I ground the edged until almost sharp and then a 'flap' disc or even a fine cutting disc in a 4.5" angle grinder. The thin 1mm cutting discs are made from fine abrasive and if used carefully, will hone a really nice clean smooth edge.
    I the grabbed a piece of blackwood off cut laying aroind, cut a thin groove in it with the table saw, mixed up some 2 pack adhesive and glued the blade innto the handle.
    Wholla! all done bar the clear sealer.
    Cheers.
    Neill’s Pompeiii #1
    Neill’s kitchen underway
