Tapering bricks in the upper courses
  • Harpist
    • Jul 2010
    • 17
    Howdy folks,
    Greetings from North Idaho on the shores of Lake Pend Oreille. My apologies if this is a duplicate post, but I have not been able to locate the question that I posted during the weekend.
    I am building a 40" hemispherical oven dome and I have a question regarding the upper brick courses in the oven dome.
    Is it better to taper the bricks for each course (for strength and/or insulation) as compared to keeping a straight edge and having an angled gap between the bricks within a course? Obviously, not having to taper each brick is a lot easier (although you end up using more mortar).
    Also, I assume that I should progressively decrease the brick width for each course of bricks (for better fit to the course below it). Is this correct?
    Thank you for your assistance.
    Good Roads
    Harpist
  • Neil2
    • Oct 2006
    • 1374
    Re: Tapering bricks in the upper courses
    On the upper courses of a 40 incher you will want to taper or bevel the bricks. You will actually end up doing a "double bevel".
    This is easier than it sounds and as you get into it you will see what I mean.. A cheap chop saw with a diamond cutting blade will do the trick.
    You may also want to pick up one of these, a bevel setter. It will speed up getting the changing angles correct for the cuts.
    • SCChris
      • Jun 2009
      • 1213
      Harpist,
      Vertical brick joints that span courses is what you're trying to avoid. The bricks are stronger than the joints and if you can avoid spanning courses I think your oven will be stronger for it. If you choose to decrease the width of the brick and can avoid brick joints spanning courses, great! I think you'll be happier ignoring the brick width and focusing on spanning vertical joints. I'm including a link to a tool that helped me deal with dome brick cuts. I'm quick to say that an oven built with half bricks, and loads of mortar, will cook the same as a oven built with taylor cut bricks.
      Chris
