DIY oven tools
  • countryboy
    • Jun 2010
    • 157
    #16
    Re: DIY oven tools
    Thanks guys.
    Still need a wooden peel and have an improvise idea... Searched all over this area for a long handled peel and nobody had one. The shorthandled peels were either pricey or not to my liking.
    I have a solution and will post pics soon as I can fabricate it.
    Would scratch make one like George, but don't have a biscuit cutter.
    CB
    ____________________
    My 42" WFO/outdoor kitchen build thread:
    http://www.fornobravo.com/forum/f8/c...-us-13256.html
    • countryboy
      • Jun 2010
      • 157
      #17
      Re: DIY oven tools
      Found what I needed the day before yesterday... First night for pizza tonight, so HAD to finish a bunch of stuff today. One thing is the wooden peel.
      Found a nice bamboo tray that was thin,laminated and exceptionally strong and durable... Used an old post hole digger handle the boys have been stick/sword fighting with and several carriage bolts... Some sanding to further taper the leading edge as well as a little sanding on the handle, and I am happy with the final product.
      I will need to poly the handle for durability, but the peel is pretreated with a food safe oil of some sort.
      Pics follow.
      Also, see my WFO thread for pics of the cleaned up work area and nearly finished oven!
      CB
      • fxpose
        • Jul 2009
        • 942
        #18
        Re: DIY oven tools
        CB....your wooden tray idea is great! I'll do that with next peel project.
        George
        My 34" WFO build
        • countryboy
          • Jun 2010
          • 157
          #19
          Re: DIY oven tools
          Thanks, FX.
          Worked like a charm.... For putting the bread in. Worked fine with the pizza, but the coal bank was so large on this first run that we only had a small area just inside the door that we cooked on... Could have easily reached with a short handled peel.
          May get/make a short peel for near placement and use the longer one for deeper in the oven.
          CB
          • fxpose
            • Jul 2009
            • 942
            #20
            Re: DIY oven tools
            I turned my old short handled kitchen oven peel into a long handled turning peel:
            George
            My 34" WFO build
            • asudavew
              • Jul 2007
              • 1880
              #21
              Re: DIY oven tools
              Excellent work. Those tools would be a pleasure to use.
              You might try making yourself a wire brush to clean the deck of the oven.
              I think you will find it extremely handy.
              My thread:
              My costs:
              My pics:
              • countryboy
                • Jun 2010
                • 157
                #22
                Re: DIY oven tools
                George,
                The turning peel adaptation looks good. Well done!
                I had some time this morning to make a tool holding rack. The primary purpose for this is to have a place outside to store my oven tools where they will be protected from the weather.
                I decided on a nice place under the eave near the back door. It is not close enough to the oven to hold tools while not in use, so I'll be making a little floor holder to employ when the oven is active and the rest of the time the tools can hang on this rack.
                For starters I scrounged a 48" section of 2x4 aluminum tubing. Then I roughed out the sections I needed to cut...
                Frankly, this could easily be made with an angle grinder and a cut-off wheel or two, but I was too lazy to prove anyone could do this with hand tools... Instead, I am blessed to have a few nice tools at my disposal in my messy shop...
                Pics show me using a mill to machine out the sections I needed removed, then I used an angle grinder with flap disc and a hand file to de-burr and break sharp edges.
                Following that I powder coated with a nice wrinkle black... (The average DIYer could simple use rattle can spray paint.) Last I marked, drilled and mounted the rack on the wall... See pics.
                I'll post pics when I get around to building a freestanding floor tool rack. (Though I really like someone's birdbath stand... Might have to dream up something cool along those lines. I do like cool unusual solutions like that.)
                CB
                CB
                • countryboy
                  • Jun 2010
                  • 157
                  #23
                  Re: DIY oven tools
                  And, a few more pics of the build and completed rack...
                  Enjoy.
                  CB
