I stack bricks in the oven opening and then I place a three plywood thick door over the opening. It has worked very for well except this morning, all that is left is ashes and the bricks. Any thoughts on a insulating door design.
Oven door is gone!
Re: Oven door is gone!
R.I.P. Doc Opa's oven door...
I built an aluminum box with 2" of insulating blanket in it and a long stem thermometer stuck through it. Simple, light, and insulates well.5 PhotosLast edited by fxpose; 09-05-2010, 01:39 PM. -
Where did it go?Check out my pictures here:
If at first you don't succeed... Skydiving isn't for you.Comment
Yep. Been there, done that!
I got up the next morning and looked out and noticed the door missing. I was thinking "I'm sure that I put that door on last night" It wasn't until I noticed the pile of ashes that I figured out what had happened.
I'm still on my 2nd temporary door which is just a bit of 12mm plywood fixed onto an aerated concrete block. One day I'll get around to making a permanent door.Paul
(Failure is nothing but the opportunity to start again)Comment
I caught mine just in time - was about to load the oven up with bread when I saw smoke pouring off the door. It's a little charred but still quite solid.My Clay Oven build:
http://www.fornobravo.com/forum/f43/...dah-12821.htmlComment
I thought man, that smells like burning cedar...and yep, it was my door!
Only charred the inside, but would have lost it completely if I was away a few more minutes. Working on a permanent insulated door soon...if I ever get to it...Ernie
Ducane 5 Burner Stainless / 34 Inch WFOComment
fxpose - what thickness Alu that is? Did you notice any heat damage on it?my own Quest for Fire:
http://www.flickr.com/photos/leckig/Comment
No heat damage yet, but I expect it to eventually crack or tear. If it does, I can easily replace the inner alu face with 22 ga sheet metal.
The sheet aluminum came from a couple of large alu food serving trays which I had laying around. The alu was soft and pliable so it was very easy to cut and bend to shape.Comment
so looks like you think 22 ga metal may work better? Did you put any frame inside that box? I need to make door this weekend, I really like your concept!my own Quest for Fire:
No, absolutely no framing. I originally thought about framing because the alu felt so flimsy but after I started bending and riveting the sections together it became very rigid.Comment
awesome! Time to buy a riveter
