Hi Everyone.
I've run into some problems while build a vault oven (yes yes i know ....). I'm hoping someone might be able to help me find a solution(s) to my problem(s).
Basically where my side walls are, i rushed my concreting and the walls "bowed" and push out. This now leave me with very limited space for insultion, maybe ~5cm (with a brick exterioir) or maybe about 10cm if i get rid of an upper brick exterior and do some sort of metal housing cage.
Given say 5~7.5cm of space, what would you use to best insulate the oven?
Would really appreciate any advice and/or help.
Cheers,
Gi
Cheers,
Gi
