My small crack in my outer arch now runs across the dome about half way down the back. The arch portion opens enough to slip a quarter in. It continues thru the top left side of my vent and then through my inner arch, although does not open up so much. The dome however opens up enough for me to see some smoke comming out. I noticed this last night near the center during my 700 degree curing fire. 800 degree and final curing will be tonight, then I need a plan to do my fixing.
I've heard some people using RUTLAND furnace cement across their domes and fireplace mortar for whats visible. However, I noticed mixed results due to the heat curing requuired for the products. A post from someone in Hawaii had good luck by filling cracks while firing the oven and torching the exposed areas from the outside. Sorry I didn't save the url to post the link to that post here.
Also, I added about 3/8 inch of heatstop to the outside of my dome when building so, I'm hoping the line I see outside matches through to the portion leaking in the dome.
Feedback please....
Feedback please....
