Include a thermal break between the inner and outer arch if you want to improve heat retention.
David, would you mind defining a 'thermal break'?
I'm thinking about inserting about 5 or 6 insulated firebricks from right to left on the oven landing just outside the first oven arch....Is that what you mean?
Lee B.
DFW area, Texas, USA
Yeah, I use only 10mm vermicrete, but it is way better than direct contact.Apart from reducing heat conduction=heat loss, it also provides space for thermal expansion of the inner parts of the oven which avoids pressure on the outer arch.
