Hi all,
Let me start by saying how much I have appreciated all of the information I have read on the Forno Bravo forum, which has led me to begin building my own Pompeii oven. The build is going well and is up to the second row.
Question 1
I have a question about mortar. I am using a castable refractory product which comes dry, I just add water and hey presto a fantastic mortar! This stuff is super strong and has bonded really well with the firebricks. It is easy to work with and goes off reasonably quickly to allow me to move on with the build. My question is, can I use another type of mortar to fill in the small gaps? The castable refractory has small aggregate in it which is approximately 3mm in size. Not great for the tiny corners where the brick faces meet. I am considering sifting out the aggregate and using the finer mix. Kind of like a grout, and use this mix to point up small gaps. I'd love to know everyones thoughts on this.
Question 2
Also I have large gaps at the back of the bricks that will need to be backfilled. Castable refractory mix is going to get expensive if I fill all of the big gaps with this. Can I use a cheaper/home made mortar to fill up the gaps at the back?
My refractory supplier sells Cement Fondue which can be mixed with sand. Would this be a good solution to both my problems, it is cheaper and only seems to have sand as the aggregate (unless I am mistaken)
Anyway, I've searched high and low on the forum but not found anyone that has mixed mortar types. I am keen to know what the best way forward should be?
Thanks in advance
Question 1
Question 2
Thanks in advance
