Reccommended Flue sizes direct from Italy
  • sonomacast
    • Jul 2006
    • 150
    I found this on an italian Oven building web site
    Diametro del forno diametro minimo canna fumaria in cm
    da 60 a 80 ----cm 20
    da 80 a 120--- cm 25
    da 120 cm in--- su 30
    Costruzione e uso del forno a legna
    Translated... Translation result for http://www.fuocoelegna.it/costruzione.php
  • stoveup
    • Sep 2010
    • 85
    Re: Reccommended Flue sizes direct from Italy
    My Italian is nonexistent and the translation is, um....interesting. However, it looks like the chart is recommending a 10" diameter flue (approximately 25 cm) for a 42" diameter oven (approximately 100 cm).
    I believe this is somewhat larger than the FB plans calls for.
