I can't reach the back of my cob oven too well to scrape out the last bits of the sand that originally formed it. This brought up a larger question to me of how I intended to get all the ash out of there. This brought up another question in me of how I was intending to push all the wood around when I was starting the fire.
It will be another week I think before I can really take this thing up to a good temperature so I wanted to learn a little bit more about good tools to use in the oven that I should probably have at the ready when it is time. I already have a pizza peel, but that was the easy part.
We have a nice hoe here that might push the wood around, and I initially was using it to scrape out the sand, but I couldn't get it into the curves right at the edges, so a lot got left behind. I am assuming there is a kind of brush that is like 45 degrees to the handle, all made of materials capable of withstanding high heat. I guess it could be like a workshop broom you'd use at home. But so far I haven't found one. When I looked up fireplace brushes on Amazon they all appeared to point straight out from the pole. Is that normal? Is that better?
