I am about to order some fire bricks to build a pompeii oven. The smaller one I believe 36". I see It states you need approximately 130 bricks, but in the plans it states you will need 130 half bricks. Does anyone know what I should order. Half or full size.The pics appear to indicate half bricks for the dome
question on fire brick
Re: question on fire brick
The dome is built of half-bricks, but you will have to cut them yourself. I have not heard of anyone finding half-bricks for sale. There are several ways to cut the bricks - check out some of the build threads on this forum to see how others have done it. There is a thread in the Newbie Forum here: A newbie?s survey of the Forno Bravo treasures hiding in the archives that will point you toward several especially helpful builds.
There is also a description of the various ways to cut bricks in the free pompeii oven plans.
Good Luck!
There are half size fire bricks - but half in the thin dimension. They're called "splits" and they are usually the same price as full size bricks. You don't want these. The regular firebrick that you can buy at a masonry supply or brickyard is what you want. Halving bricks is pretty simple: a diamond saw cuts them easily, you can even break them in half with a special chisel called a brickset. You'll probably want some kind of diamond saw, as some trimming is called for in even the most simple build.Comment
Hey thanks guys. I found a place that does sell half bricks but now with the info I just got I will have to go and see them rather thenvjust a phone call. If they are splits ill be buying full bricks. Thanks very much for your help. I'm very excited about doing this and could use allot of help lol
MichaelComment
Get 130 whole bricks, if that is what the plans call for, plus enough extra to save a trip to buy more after you make a few mistakes.....Maybe 10-20 extra.
Lee B.
DFW area, Texas, USA
I try to learn from my mistakes, and from yours when you give me a heads up.Comment
