Home made pizza cutter.
Here is a pizza cutter I made out of Huon Pine and stainless steel, two of the most enduring materials you can get.
Its fairly simple, cut a slot in the timber to take the stainless cutter blade.
Use a durable timber as it has to be washed.
Also make sure the blade has a slight bend in it to keep it secure in the timber slot.
