Secret to setting Toscana oven
  • Secret to setting Toscana oven
    Recently I received a Toscana 90 on a pallet. I inquired as to how to set on the stand and did not receive much information.
    Well the oven arrived and after some thought I used a fork lift, removed the wooden runners on the bottom and tried to figure out how to get the forks out so the oven set flat.
    I bought four bags of crushed ice and placed two bags of ice along each fork on the stand. I lowered the oven on the ice bags and removed the forks. zIt was easy to adjust the location of the oven on the stand and when the ice melted the oven was flat on the stand, right where I wanted it.
    Re: Secret to setting Toscana oven
    I like that
      Brilliant!! For some of us though, the way the weather has been, the ice would not melt until August.
        Great idea! I've heard of guys aligning large outdoor kitchen granite countertops on ice cubes and once the ice melts you're good to go. If I ever have to replace the soapstone slabs in my oven I'm gonna have to slide them out on a cookie-sheet slab of ice or else leave them in there.
