Hi All,
Came up with this idea for an oven door.
As I couldn't easily fabricate steel plate, I decided to use what was available and easy to form.
I used a piece of hardwood for the outer layer, then placed a sheet of ceramic sheet, then a layer of 40mm square galvanised steel tube laid on top of each other, then another layer of ceramic board. All held together with coach bolts.
Looks okay....will let you know how it performs.
My only concern is how the ceramic board holds up to the wear and tear of being moved around etc.
