Electricity generated from a WFO.
  • Neil2
    Re: Electricity generated from a WFO.
    "pressure from the hot water"
    Pressure ?
    Unless you are a boiler engineer, I would hesitate to try a home made pressure system.
  • sonomacast
    I did think sterling engine but it also seems out of the question, maybe a combo of everything possible, surely the pressure rising from the chimney alone would turn a prop, pressure from the hot water a piston and generated heat a sterling engine.
  • Les
    Originally posted by sonomacast View Post
    Steam power is all I can think of?
    Not at all. A sterling engine would be the ticket. I don't understand why they are not mandatory in every chimney. Hot and cold equals power. Hell - hot and less hot equals power.
    "I think it's a pipe dream"
    Don't discount the pipe. It can be instrumental in the production of some very innovative ideas.
  • brokencookie
    Either steam ( since they mention hot water) or some kind of bi-metalic strip. But I can't see it producing too much energy. The steam idea might work but the safety factors ( PRVs etc) would end up making the system costly and expensive. I think it's a pipe dream
  • sonomacast
    started a topic Electricity generated from a WFO.
    Electricity generated from a WFO, Sure, this crowd seem to be working on something, How do you think it works? Steam power is all I can think of?
    Generator. What Generator? | Dragon Ovens
