Ok, so I've cut the 1/2 bricks for the first couple of courses; using sailors (soldiers laying down). I've run into a problem.
I've made my homebrew 3:1:1:1 and the consistency seems great. It helps that the weather is in the 70s. I've wet my bricks (dipped in water for a few minutes) and then drain for a couple of minutes. Thought everything was going well. Then comes the time to put the mortar to the bricks. I start at the back center. Put brick against indispensable tool, put brick into position - yeah - this seems easy enough. Get next brick, slap some homebrew on the side; shave the extra off the top and bottom, slide corner next to first brick with positioning assistance of I-tool. Two down - this is going to be easy.
Or at least that's what I thought.
Third brick same process, but as I slide the brick against brick two, the assembly of three bricks moves/slides -oops. Grab first brick in left hand and third in right and slide back in to position.
Fourth brick - wind up with a small crack between brick 2 and mortar. Tried to squeeze it back together. Will this still be a strong joint? Probably doesn't matter on sailor course, but I figure it will happen again on later courses. Should I be taking it apart and redoing it?
It also happened at other joints as I added more sailors.
It took me an hour to do the first half of the first course. I'm sure I'll get more adept at it, but want don't want to build inherently weak interfaces.
Any good videos out there of the bricks being mortared and positioned?
Thanks for your help!
Jeff
Jeff
