I have noticed the black discoloring left form the smoke on the decorative part of almost every oven.
Has anyone designed a chimney that eliminates this problem?
I was thinking of placing a thinner secondary transition into the chimney closer to my decorative arch.
Maybe just use smaller slices of brick for the top inner vent arch right before it reaches the decorative arch or entry way.
This should give the black smoke another chance to move up into the chimney instead of exiting through the front.
Or at least cut down on the amount that comes out the front.
