sand under firebricks? - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • sand under firebricks?
    We're pouring cement for the hearth this afternoon on top of concrete backer board, I've ordered FB board from Forno which should be here soon. I'm seeing different options of putting a thin layer of sand between the FB board and the firebricks versus using a sticky mortar. Which is best? I'd like to be able to remove damaged bricks over time and think the mortar wouldn't allow me to do that. We're planning an igloo with 2 layers of FB Blanket and concrete. Do I need to use refractory concrete on this? or will regular work?
    Will post photos if I can figure out how...
    Thanks - I'm really excited about this and am so grateful to the Forno website!
    Re: sand under firebricks?
    I put dried fire clay under mine... wow 4 years ago. And the bricks are still quite flat. It seemed to take up for the irregularity in the fire brick. I was lucky, my bricks were quite uniform to begin with.
    My oven progress -
    sigpic
      This may sound nuts, but... I am a sculptor and have lots of bags of clay around, including some that is too dry to work with. Traditional oven says I can use that, let it dry and crush to a powder to be my fire clay. Do you see any problem with that? It sounds so logical to me, I guess that's what makes it sound nuts. I really like your oven, cristo, good job. Now that you've had it 4years, how often would you say you use it? I'm curious if the novelty will wear off, or if it becomes even more of an obsession over time! My husband and I are already drooling over the possibilities...
        Hi
        Use the fireclay.... its fired and will not soak up moisture and return to soft clay. It still has the properties of clay which allows slip betwwen the particles and helps in the expantion/contraction during heating/cooling of a WFO. I have just found this out and am thankfully that I did use fireclay to set my hearth bricks and as a component of the home brew fireproof cement.
        Regards Dave
          Some clay can fire at low temps (that would be a bad thing). I am sure someone here has measured the temps below the hearth bricks. I know the dome will go off the chart. What temp is recommended to fire your clay?
            Hi
            Regards Dave
            Dave,
            I think you are confusing fireclay with grog or chamotte, which is crushed and fired clay. Fireclay (unfired) will certainly turn back into mud if it gets wet enough.
            Any unfired clay will not become permanent until it reaches the quartz inversion stage (573 C) too high for a WFO.
            Dave
              David,
              I may be off base but 573c is only 1063 f. If I am cooking at 750 - 800 f after I let it cool down, are you sure we don't hit that temp? My laser only goes to a few clicks below 1000 but it pegs every time I fire the oven. If I recall, I thought someone fired some clay a few years back in their oven. I only bring it up because sitting your brick in glass has got to be worse than mortar.
                There's no way you will get near melting glass. That occurs at around 900C depending on the glass type, unless you throw in some small beer bottles some of which I'm told are partly plastic. They will melt in a fire. The surface of the oven crown may go over 573 C but not the rest of the oven.
                I have fired clay many times in a campfire, directly in the coals. That is sufficient to fire the clay. The tricky part is to increase the temp slow enough not to crack the pots. Sometimes there are portions of the pots that did not get hot enough and you can wash the clay away there.
                  My clay is a low fire terra cotta, so it won't work, I fire it at about cone 06. Does anyone ever just set the firebricks directly on the FB board? Can I put a layer of vermiculite down? Regular sand is probably not a good idea, as one really good fire could melt it into glass? I've melted bottles in my kiln before at 06.
                  I really appreciate the advice - I would have never attempted building a WFO before this website. If I get the refractory/ fireplace mortar I won't need the homebrew? Is that correct?
                    Usually the mix for under the floor is a 50/50 sand, fireclay. This is only required to get the bricks level. Place them directly on the insulating board if you want. Do not be concerned about sand melting, it won't. It needs the presence of fluxes to lower it's melting point anyway and you are not adding any to the mix.
                      David s
                      Again thanks for clearing things up... your a font of knowledge.
                      I think I have made a wrong asumption after reading that the slurry left with a bricksaw was a source of fireclay
                      Regards Dave
                        Just use your terra cotta clay, but crush it up to powder then mix it 50/50 with sand. an 06 cone is around 1000 C you won't get anywhere near that. To melt terra cotta you would have to fire it up to stoneware temps.You canpurchase the refractory mortar, but be careful, some of them only work when fired to much higher temps than your WFO will reach, so they are then ineffective. Best to use the homebrew IMO.
                          I am one of the guilty for using sand - I for one have not had any problems with it and feel it is serving me well. Reason I used it was the fact that getting bags of fire clay is a pain since very few here in the desert SW have fireplaces. I have to drive an hour to get a flu liner if the local masonry shop does not have them in stock.
                          CW
                          Follow my build Chris' WFO
                            Next question. The FB board arrived and it's a softer material than I expected. Do I : 1. cut it to fit the INSIDE of the pizza oven so that only the floor of the oven sets on it?
                            or: 2. let it overlap the 36" interior allowing the bricks for the dome to sit on it?
                            If it's #1, then do I cut the floor firebricks to fit the same foot print, putting the soldier course outside of it entirely?
                            Our hearth is only 54" by 60", will it be a problem to make it an inch or two closer to the back edge, so that I can have a bigger landing? That means that for about 3 or 4 inches across the back, the insulation layer of concrete will be slightly thinner that other places.
                            Thanks! ~ Shelley
                              Thanks! ~ Shelley
                              All heated material needs to sit on the insulated board. And concrete is not insulating material so I am not sure what the insulating layer of concrete refers to.
                              Chip
                              Chip
