Fire clay failure.
  • brickie in oz
    • 3445
    Fire clay failure.
    Fire clay failure.
    Many years ago long before I got onto wood ovens, fire clay and all that stuff, I was asked by a builder to build him a fire place, and chimney, no problems.
    He was one of the most stubborn blokes I have ever met and you couldnt discus or differ from his "way" whats so ever, anyway, as I get prepared to start building the fire box he gives me a plain brown paper sack with the words "Fire Clay" and nothing else printed on the side.
    He told me its what I have to use to build the fire box and roll back, I asked what I mix with it and he said "nothing just water".
    I told him it wouldnt set as its basically just mud and as soon as it gets moist from the atmosphere in the air it will be mud again.
    I mixed it as directed and all I got was some brown gloop that was basically unusable, I queried the directions only to get yelled at, so I proceeded to build the fire box.
    As I was laying the courses you could see the who lot wriggling around and moving, once again I queried only to get more abuse.
    I finished off the fire place and chimney but you could see the whole lot slumping very very slowly. I got paid and was gone.
    About 3 weeks later the builder rings me up and tells me the whole lot had collapsed, I just laughed and told him it was his method with the fire clay that caused it.
    When he asked if I could go and redo it all again I laughed and hung up the phone.
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Fire clay failure.
    Actually, the old school masons around here do it exactly like that. Basically they make a slurry, dip the bedded face in it and lay the fireplace up. The secret is that you have to have dimensionally perfect brick and basically no joint. I see fireplaces that are 50 to 150 years old that were done this way still working fine. I still sell the fireclay, although I have edumacted most of them, even the old timers, about the advantages of using refractory cement, either home made or pre-mixed.
    • brickie in oz
      • 3445
      Yep, thats how it was done.
      Have you any pics of the fireplaces?
      • Tscarborough
        • Oct 2009
        • 3341
        No, normally when I am called to look at them it is not for issues with the firebox but of the cap and chimney.
        • Lancer
          • 423
          Ever see anything like this brickie? I was pretty amazed and figured 'if this works I'll be okay with my build.'
          How to make a cob oven or clay oven Part three - YouTube
          • sandgroper
            • May 2013
            • 8
            This sounds more akin to refractory work which requires a specific brick more suited to kilns than a fire place or oven.
            Read Forno Bravos mortar mixes which are more suited for lower temp items than making steel.
            Id say you were bullied by the self righteous Brickie
            • Lancer
              • 423
              I have worked for the sort that brickie described, full of themselves, unable to learn through their pride...I know exactly the frustrations brickie was dealing with. To be a professional and be told to do something one knows is wrong is a very difficult position to be put in.
              It sounds like brickie's "bloke" was one of these, and must live with the results.
