Perforated Pizza Disk - for parties?
  • mrchipster
    • Apr 2010
    • 1502
    I would like my guests to be able to build their own pies but I am concerned about the sticking pizza problem.
    Does anyone have experience with Perforated Pizza Disks
    To allow guests to build a pizza on the disk, throw the whole thing in the oven and then move the pizza off the disk after the bottom has set.
    Chip
    Chip
  • Les
    • Sep 2005
    • 2945
    Re: Perforated Pizza Disk - for parties?
    Chip,
    Our guests make their own but we have them use a ton of corn meal on the peel. We also try to keep them moving to prevent the dough from hydrating into the peel. Where are these sold, I might give one a try?
    • Faith In Virginia
      • Oct 2010
      • 713
      I do that all the time and I don't think you will have any problems at all doing it that way. I make a sourdough crust so I like it to set for a while after I stretch it out.
      • Faith In Virginia
        • Oct 2010
        • 713
        Les, I use an air bake pan and you can find them at Target and Wall-Mart and such.
        • mrchipster
          • Apr 2010
          • 1502
          Les,
          I found them at
          Pizza Supplies
          They have a lot of other stuff. the thing I like about these is that they have no rim so easy on and off for the pie.
          Chip
          Chip
          • Les
            • Sep 2005
            • 2945
            Cool - no clue what they are but I will check it out. Thanks!
            • brickie in oz
              • 3445
              We get our guests to build the pizza on a tray/pan, oil the pan, spread dough, flip dough, build pizza.
              Bake until the dough is firm, remove from tray and put on bricks to crisp, we rarely get a problem.
              • metalmaster
                • Mar 2008
                • 62
                we use the wire mesh screens when we do big parties (50 pizzas) and they work great
                • mrchipster
                  • Apr 2010
                  • 1502
                  I looked at the mesh also, Do you remove the pizza from the mesh or leave it on for the whole cooking cycle?
                  And how do they hold up over time? They look a little flimsy.
                  Chip
                  Chip
                  • metalmaster
                    • Mar 2008
                    • 62
                    we take the pizzas off as soon as they cook enough to slide off.
                    we have used them for over 300 pizzas so far and they look as good as new.
                    • BrianShaw
                      • Jul 2007
                      • 308
                      ditto. Mine have (probably) over 300 uses and are dark with, umm, darkness, and getting rather bent up... but continue working fine. I only replace them if the edge starts to fall apart because they can cut fingers when that happens.
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        I have and use pans, disks, and screens. The disks are a PIA because you can't get the peel under them. Occasionally the screens stick, so normally I use the pans if anything.
                        • tony5885
                          • Oct 2011
                          • 1
                          Just spread some flouer under Your pizza will be fine!
                          Best pizza in Las Vegas FREE ADVERTISING
