Sorry to be posting multiple threads. I prefer one thread per specific topic instead of broad discussions that explore an idea from multiple directions.
That said...
So, the 'ol pressure-treated wooden post in a concrete footing. It's a classic. I'm curious if I can make the post slide in an out of the hole with just enough give to be removable, but tight enough to minimize looseness and sway (to ease pole replacement as the wood wears out every several years). My current idea is to wrap the pole in plastic before pouring the concrete and perhaps giving it a touch of occasional vertical motion while the concrete is setting so it doesn't stick (lift it up a smidge and let it drop back down).
Two questions:
Is this a royally bad idea (the response I expect to get to this thread I suppose)?
What other or additional steps might assist this goal? Should I coat the plastic with something slick (e.g I've heard you can coat the plywood form of a concrete fill with motor oil to make the wood easier to remove). Should I coat the inside (wood) the outside (concrete) or both sides of the plastic (or perhaps between multiple layers of plastic)? Would a slipping agent of this sort make any difference many years later? I'm rather doubtful on this point which obviates any purpose to adding a slipping agent (oil) in the first place.
I was kind of thinking of inserting something thin next to the pole during the pour (masonite or a comparably thick sheet of metal) and then removing it after setting to make a tiny gap so the pole has some room...but the masonite or piece of metal itself could get locked in tight during setting and be too tight to remove after the fact, which would negate the purpose of such an approach.
I know I throw a lot of crazy ideas out on this forum. Any thoughts are, as always, appreciated.
Cheers!
That said...
Two questions:
Cheers!
