Steel pipe vs. rebar-concrete-filled-PVC for a column
  • kebwi
    • Aug 2009
    • 1090
    To make a short sturdy column, embedded about three feet deep and extending three to five feet above ground, and of diameter approximately three to four inches (to be a "foot" over which to slide the end of a tall vertical pole) one might conventionally use a piece of steel pipe...but I think that's expensive and troublingly difficult to source.
    Another way is to use a PVC pipe, drop a bunch of rebar in it, and fill the whole thing with concrete.
    Such pipes are common in other uses (telescope pier mounts for example). Non PVC concrete pillars are, of course, a basic staple of construction, but those primarily bear a vertical load whereas the purpose of the column in my application is to provide lateral resistence to a "balancy" vertical pole (plus additional lateral forces, see other thread for more on that). An all-concrete column would obviously be a bad candidate for a "sideways-pushing" (lateral) requirement since it could simply break...but with the flexible yet strong PVC holding it all in place and with sufficient rebar to skeletonize the whole thing, I think it has potential.
    Do you think this would work? Would it adequately support a vertical pole in the same basic fashion as a steel pipe? If so, how would you trade off the amount of rebar vs. the amount of concrete?...or would you never in a million years go near this insane idea?
  • metalmaster
    • Mar 2008
    • 62
    Re: Steel pipe vs. rebar-concrete-filled-PVC for a column
    I would go with the steel pipe, the concrete will want to break away from the rebar when it flexes, and the pvc gets brittle over time.
    you should be able to source a short piece of pipe without to much trouble
    mike
    • kebwi
      • Aug 2009
      • 1090
      Yeah, for $100. Dammit.
      Okay, thanks.
      • Tscarborough
        • Oct 2009
        • 3341
        A fence post shouldn't cost a hundred bucks. Buy the thin gauge fence post and fill IT with concrete (no rebar needed).
        • kebwi
          • Aug 2009
          • 1090
          Thanks Tscarborough.
          • deejayoh
            • Jul 2010
            • 1893
            I've got some cyclone fencing I need to cut down. You can have a post
            • kebwi
              • Aug 2009
              • 1090
              So, the primary pole is about 3-1/2" inner diameter at the bottom and I will slide that over anchor pole a few feet high (embedded in concrete). I got some thin-walled (1/16") fencing conduit 2-3/8" wide, which is about as wide as can be easily found. If I slide the primary pole over that, it's going to have a lot of freedom to flop around. I think I should "thicken" the inner pole somehow. Not to mention, if I place something nonmetalic between the two poles they won't clank too loudly. A piece of 3" PVC is 3-1/2" outer diameter, which is perfect to fit inside the primary pole, but it's still too lose relative to the inner pole (2-3/8").
              What would you do about this? How would you tighten up this gap so the two poles fit together more snuggly?
              • Tscarborough
                • Oct 2009
                • 3341
                Have you ever used a cheap Christmas tree stand?
                • kebwi
                  • Aug 2009
                  • 1090
                  Hmmm, the kind I'm familiar with puts screws through the stand to touch the (and even penetrate) the tree. I was hoping not to drill holes in the nice aluminum pole. When we all discussed this method of anchoring the primary pole by sliding over a shorter thinner pole, was that the intention all along? --that I would bolt through both poles? I could do that, I just hate to ruin a nice pole. :-)
                  Was that the idea?
                  I guess I could just place some bolts through the inner pole which achieve an "outer diameter" of the inner diameter of the outer pole.
                  • Tscarborough
                    • Oct 2009
                    • 3341
                    You just need one, and you could do it low if you like, although you will get more noise if you do so.
                    • deejayoh
                      • Jul 2010
                      • 1893
                      Get two pieces of PVC pipe. Drop the first one over the pipe. Cut a split in the second one - or maybe even a section out - and drop it over the first one. Should give yo a fine shim to fit perfectly.
                      • metalmaster
                        • Mar 2008
                        • 62
                        1/16 wall tubing is to weak for this application
                        you need to go with 3/16 wall pipe
                        think about what you could lose if the whole thing comes crashing down
                        better to spend the 100$ on the proper material
                        mike
                        • kebwi
                          • Aug 2009
                          • 1090
                          mike
                          Well, I agree with you. I never had any illusions that 1/16" fence pipe would offer much strength. That's why I was going to drop rebar in it and fill it with concrete. I can fit two pieces of 1" rebar inside the 2-3/8" pipe (I have access to some 1" rebar, pretty insane stuff).
                          But, I can also splurge for a steel pipe too, I'm talking to guy I found on Craigslist who has a reasonable deal . I just didn't want there to be any confusion on this. I didn't mean to suggest that I thought the thin-walled stuff would actually hold it up empty on it's own.
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            It wont, but full of concrete it will, and you do not want rebar in it, especially #8.
                            • kebwi
                              • Aug 2009
                              • 1090
                              Not to belabor a discussion that is probably not worth the trouble, but I'm curious why one would specifically avoid adding rebar to increase the rigidity of a concrete pole. I haven't seen a reason *why* that would be the correct approach. I'm just curious, I like the understand the reason behind things.
