I've uploaded some pictures of a Premio 100 build. This is the older version which is no longer sold as far as I can tell. Someone had this and it had sat around a few years. I picked it up and it too sat for more than a year. We finally got a design, found a mason, and began the build this Fall.
The overall construction is concrete block with flagstone strip exterior. Lots of rebar and angle iron. Likely a complete overkill. We have a prep area on one side and a stone farm sink on the other. The island will have stainless inserts from Costco. These are manufactured by Bull and seem quite durable and are reasonably priced.
We went with 2" thick flagstone for the counter tops and 1" thick for the roof. The strip stone is about 3" to 4" thick and varies in height.
We have a 6" base for the oven and FB insulated board on top of that where the oven based was placed.
The base for the oven has two wood storage areas. We have one in front and one in back which will have a door made from reclaimed lumber (from an old barn). Each section is about 24" deep.
The foundation is about 12" deep. We plan on having a flagstone patio around the whole oven island, so we didn't extend it much beyond the base. There's water from the garage to the island. We used a french drain for the sink into a small cistern.
I will post more pictures as it nears completion. The templates for the countertop are at the flagstone supplier and we'll likely finish next week.
