Oven Lights
  • Xabia Jim
    • Dec 2006
    • 1168
    Oven Lights
    I'm using the wood flame in the oven, a flashlight and a bare bulb!! Yeah, it's still winter in the northern hemisphere!
    Has anyone found an interior oven light for your oven that will withstand the 1000 degree heat? James, I assume there's something for FB commercially?
    Apart from throwing in a bit of pine kindling, what works for lighting your oven?
    XJ
  • Richard
    • Mar 2006
    • 162
    Re: Oven Lights
    When baking pizza's there is sufficient light to see that crust browning arounf the edges, even at the back of the oven.
    When roasting or baking, especially in the evening, I use a flashlight.
    • chefbru
      • Feb 2007
      • 4
      Re: Oven Lights
      try using chips in addition to split logs. It's amazing how much light you get from a little scoop of chips. they are also a great way to get a quick blast of heat.
      -chefbru
      • Hendo
        • Oct 2006
        • 257
        Re: Oven Lights
        XJ,
        See discussion at http://www.fornobravo.com/forum/f6/i...ight-1496.html especially James' last post on that thread.
        Now if only we could find a suitable heat-proof lamp locally ....
        Paul.
        • carioca
          • Sep 2006
          • 266
          Re: Oven Lights
          Hendo,
          I just got myself a 2 million candles floodlight powered by a 6V SLA battery (intended to scare fruit bats away from my pear and nashi trees) - that should be powerful enought to light up the dome interior during the dullest bake day?
          NB: the light is by SIP of Italy and cost $A31...
          Ciao,
          Carioca
