Pizza Cutter
  • man7sell
    • 88
    Pizza Cutter
    What Santa brought me this year, a nice bamboo cutting board, just what I wanted. And a surprise, a pizza cutter. Now I have a couple of the wheels, but this tool is excellent. Shame after advertising Taste of Italy, it had a very small sticker that said made in China.
    Oh well it was a gift and a superb tool. Cuts across in one rocking motion, never drags the topping and very easy to clean.
    Capt. Paul
    Granite Falls WA, USA.
    Oven In Granite Falls
  • Derkp
    • Apr 2010
    • 188
    Re: Pizza Cutter
    I have one too. Ours has a smaller diameter gripping area so we made some hardwood handles. The rocking motion makes short work of many pizzas.
    Derk
    • Tscarborough
      • Oct 2009
      • 3341
      Re: Pizza Cutter
      Pretty nice, I need one of those types.
      • nissanneill
        • Apr 2007
        • 1886
        Re: Pizza Cutter
        Santa only brings things here for the grand kids, so you have to improvise and make it yourself.
        I made my chimney transition made from stainless steel and an offcut from over the oven and front arch was ground and made into a rocking cutter. I machined a hardwood handle, mixed up some 2 pack epoxy glue, even coloured it ti match and slid the blade into it. Has been working fine for 3 years but you do need to be careful, especially washing and drying it as it will cut you without warning.
        You will never use a roller cutter after experiencing one of these.
        Cheers.
        Neill’s Pompeiii #1
        Neill’s kitchen underway
        • TropicalCoasting
          • Dec 2011
          • 408
          Re: Pizza Cutter
          rock>roll.
          • man7sell
            • 88
            Re: Pizza Cutter
            Cheers.
            Excellent job Neill Well made.
            Capt. Paul
              Re: Pizza Cutter
              I use a rocker cutter too, in fact exactly like the one in the first post. I have also experimented around with making them and found you need to use 0.9 mm stainless. The first one I made was 0.55 mm and it was a bit too thin.
                • 5260
                Re: Pizza Cutter
                Thanks for the pics of your pizza cutter, I am on the hunt now for a piece of 316 SS to copy your design for a cutter of my own.
                • nissanneill
                  • Apr 2007
                  • 1886
                  Re: Pizza Cutter
                  316 stainless is marine grade and not necessary, 304 is food grade and more adequate for such purposes and a little cheaper.
                  My cutter was made from a stainless ally, ie. not 304 nor 316 but slighly magnetic, an offcut from the stainless kit clubman that I built, 1.6mm thick. A bit like the stainless? fridge doors that you can hang magnets on!
                  Neill taking the mother in law for a quick spin.
                  Cheers.
                  Neill’s Pompeiii #1
                  • Les
                    • Sep 2005
                    • 2945
                    Re: Pizza Cutter
                    Neill,
                    That looks like a fun car, what powers it? Edit... Just noticed your steering wheel is on the wrong side. And since it's your mother in law - you must make a LOT of hard right turns :-)
                    • nissanneill
                      • Apr 2007
                      • 1886
                      Re: Pizza Cutter
                      HI Les,
                      it's just one that I imported after rush to "have one".
                      It is a monocoque 1.6mm stainless Clubman called a Robin Hood Mark 2. I have a Mitsubishi 4G63 2.0 litre non turbo twin OHC engine in it (around 116Kw) but bolt on a turbo and immediately go to around 160 - 180kw as a Mitsubisgi Galant VR4. The kits are suited to a Ford Sierra donor cars. It has a sierra 5 speed gearbox and a Ford Cortina rear end and brakes, weighs in at close to 700Kg. Quite a fun thing to drive.
                      This one is for sale as soon as I get it registered as I also imported a Dax Rush which will have a Nissan 2.0 litre twin cam engine with around 300kw in it and is bright yellow! The chassis has been stress tested but I will not take it further until I get rid of this one. check out this very professional enterprise, they build some magnificent vehicles:
                      Home - DJ Sportscars International Ltd.
                      The Robin Hood Owners Club have a website :Portal - RHOCAR Community
                      if you are interested
                      Cheers.
                      Neill’s Pompeiii #1
                        • 5260
                        Re: Pizza Cutter
                        Very nice set of wheels, looks like a blast to drive. Thanks for the info on the SS, I'll look for all grades in my hunt. I frequent a surplus store that has all types for the same price at $2.50 US per pound so will be an inexpensive cutter but rather I can say I made it myself (I guess stole and copied it myself). Happy New Years.
                        • man7sell
                          • 88
                          Re: Pizza Cutter
                          Cheers.
                          Sure upstage me with the clubman kit. Verrrrry nice. I built a Dutton back in the day, way back in the day.
                          Capt. Paul
                          • nissanneill
                            • Apr 2007
                            • 1886
                            Re: Pizza Cutter
                            Hi Paul,
                            rather than take over this posting, I sent you an email.
                            Might need to contact James to see if we can put a suggestion for a "Members Hobbies or Interests" topic
                            Cheers.
                            Neill’s Pompeiii #1
