Quick way to bend rebar
  • Quick way to bend rebar
    Hello there!
    I needed 18 mm rebar bent into a sort of stirrups to tie concrete block stand walls together so I rigged up a quick bending set: I drilled twin holes in a tree stump 2 m from the forno site using a hand brace and 19mm spade drill, then plonked down two bits of steel, one a chisel, to act as stops. (On my first attempt at bending the rebar rod, I bent the first set of steel 'stops' instead and had a quick tumble.)
    The resulting bent rod - one of a dozen - is shown in the second snap. Third snap shows the arrangement of the first few 'ties' in place on the stand.
    Cheers,
    Carioca
    "I started out with nothing, and I've still got most of it"
    Re: Quick way to bend rebar
    Aussie ingenuity reminds me some similar easy solutions I saw in Kiwiland
      Carioca,
      I did something similar for "staples" from the rebar grid of my foundation into the Sono Tubes underneath it. Started with a large machinist's vise. Didn't work. Ended up using the bumper of an older Ford F150. Voila.
      Jim
