Crack
  • Filthymutt
    • May 2010
    • 187
    Crack
    After the massive fire. The dome itself was fine but I got a crack in my outer arch.
    Maybe 1mm between a brick on the left side of the arch and it's mortar joint on the uphill side. What I mean is, the mortar as a mass is intact but it's as if it has pulled away from the brick to leave a crack there.
    Seems still structurally sound but it's not nice to see. Like a zit on an otherwise nice face.
    Should I slather more mortar onto it or leave it be?
    Bob
    Always ready for pizza
    http://www.fornobravo.com/forum/memb...ing-build.html
  • stonecutter
    • Jun 2007
    • 2003
    Re: Crack
    Leave it....a mortar parge wont hold.
    Old World Stone & Garden
    John Ruskin
    • brickie in oz
      • 3445
      Re: Crack
      I got a very small hairline crack in mine when I first fired it, while its not a problem structurally it bugged the hell out of me.
      I racked out the joint to a depth of 5mm, moistened the joint and refilled it, it hasnt reappeared.
      • Filthymutt
        • May 2010
        • 187
        Re: Crack
        Ok thanks. It's as you said, if I just leave it be it is going to bug me forever. I think I will try your method and hope for the best. After you did that, how long did you wait, curing time, for your next firing?
        Bob
        Bob
        • boerwarrior
          • Apr 2013
          • 454
          Re: Crack
          I also filled my small cracks - a few came back (but smaller than they were) and some never re-appeared. After that I stopped worrying about them and have had no issues!
          • brickie in oz
            • 3445
            Re: Crack
            Bob
            I think I just left it till the next firing which was probably a week or so.
            • Filthymutt
              • May 2010
              • 187
              Re: Crack
              Ok cool. I'll do the same. Thanks!
              Bob
              • ATK406
                • Jul 2012
                • 206
                Re: Crack
                As with any portland cement based mortar or concrete mix, it will cure harder if you keep it wet/damp while it is curing (try to keep it damp for at least 3-5 days).
                • Tscarborough
                  • Oct 2009
                  • 3341
                  Re: Crack
                  I would not say anything, but the last statement pushes on of my buttons. Mortar and concrete are not the same thing. They do not share the same functions, only some of the same ingredients.
                  Normally with concrete you want the strongest concrete that is practical. This is NOT true with mortar. When doing a mix design for a mortar, you want the WEAKEST mortar that will suffice.
                  Concrete: High compressive and tensile strength.
                  Mortar: Weaker than the units being laid, high bond strength and flexural strength.
                    Re: Crack
                    Cracks in the outer decorative arch are not unusual in many builds. They are caused by a high difference in temp between the inner and outer surfaces of the arch's bricks, resulting in uneven thermal expansion. In addition actual expansion from the inner parts of the oven can also create physical outward pressure on the arch. Both conditions are reduced and cracks in the arch pretty much eliminated if the design incorporates an expansion joint/ heatbreak between the decorative arch and the inner oven parts.
                    • Les
                      • Sep 2005
                      • 2945
                      Re: Crack
                      Who has done that? The decorative arch is pretty much sitting at ambient temperature. Do you mean the dome and the vent/entry?
                      • mrchipster
                        • Apr 2010
                        • 1502
                        Re: Crack
                        I for one, have heat breaks at both ends of the flue arch. I know there are others out there.
                        Chip
                          Re: Crack
                          Yes, that is the point. The outside of the arch is at ambient while the inside of it is getting hot. It is similar to an uninsulated flue tile which is likely to crack because one side is hot while the other side remains cool. Lots of ovens,Rado's from traditional oven and mine as well as many others are built this way. I meant between the outer decorative arch and the entry, but on both sides of the entry like Chip's is probably even better.
                          • Les
                            • Sep 2005
                            • 2945
                            Re: Crack
                            Never seen a problem there. Mine is always cool enough to touch as the gasses have escaped up the vent. Since the brick doesn't conduct heat very well I think something else is contributing to the crack (bad masonry, shifting of the base...)
                            • Filthymutt
                              • May 2010
                              • 187
                              Re: Crack
                              Yes actually it's not really getting hot, but it definitely didn't show until that first big fire. It is just a hairline, barely 1mm
                              Bob
