Originally posted by RichC
View Post
What grits you would need depend on how your concrete is troweled off, type of aggregate used, and what you want to see as a finished surface.
You can buy a variable speed grinder and dry polishing pads ( metal bond vitrified are good) for a reasonable amount of money (google). Use respiratory protection when you dry grind. Metal bond pads are aggressive and usually only go to 200 grit. From there you can get resin bond and higher grit. Keep in mind, you want to use resin bond at lower rmp, otherwise the pads can burn.
