I'm very sorry that I wasn't clear. I did not say anything about "recalibrating for altitude". But, if you know the boiling point of water for your "elevation" (altitude) you can "test" your thermometer. I live close enough to sea level to use 212 F. Denver Bronco tailgaiters would use 202 degrees. I don't have any of the digital probes. But the manual probe that I use the most is about 2 degrees low. When probing for internal temperature, I take that into consideration.
That's the trouble with the English language, it's never clear. I really did read your post as suggesting that you need to adjust the thermometer for altitude.
Apologies. I'll shut up now.
Let me re-phrase my answer.
What Mitchamus said: you don't have to re-calibrate a thermometer for altitude. If it is right at sea level it will be right at altitude.
No matter what the device, digital or manual, you may have to test the tool for your elevation and adjust your "readings" accordingly. Here is one site that has a chart . (Sorry it is in fahernheit) If it ain't close, you may want to return it or throw it a way.
I feel another "sand vrs. marbles" exchange developing here
It's strange that raw oysters have entered this discussion. They are also reputed to increase the elevation of your tool, with or without wires and batteries.
At altitude, because the water is boiling at a lower temperature, it takes longer to raise the internal temperature of whatever food you are boiling to the temperature at which the food is considered cooked.
True.
the problem is assuming there's the same constant between temperature and 'done-ness' at sea level as there is at altitude.
what we are getting hung up on here is this constant.
The temperature of anything is always what the probe says, regardless of altitude. They never need re-calibrating. (at altitude)
What needs re-calibrating is your mental scale for 'temp vs done-ness' at altitude, especially if you are aiming for rare.
and since 'done-ness' is subjective... we could be here a long time
Reason: added (at altitude) caveat
What they are saying is that water boils at a lower temperature as the elevation goes up, because atmospheric pressure is going down.
If the thermometer reads 203 degrees at 4500 feet above see level in boiling water it doesn't mean the thermometer is reading wrong, it means the water is colder and your thermometer is right.
You don't adjust your readings according to elevation, though you do throw the thing away if it doesn't read 203 +/- a couple of degrees when immersed in boiling water at 4500 feet.
If the thermometer is "right" it will be "right" at any elevation.
The manual variety that have no wires or batteries are more reliable.
Not always, I think its pot luck with a lot of stuff this day and age.
I recently (in the last year) bought a mechanical meat thermometer at ALDI. guess what it doesn't know about expansion, bimetallic strips or spring constants. It don't work, and will burn your food.
So I think quality for a lot of manufacturing sucks, and its not always limited to price, though it can be a factor. So Ebay electronic thermometers will likely perform as well as an ebay mechanical one.
