Re: Improving 'floated' finish on concrete countertop
Damn hairline crack in the counter right at the front, the most visible spot. It doesn't appear to go right through. I assume the best solution us just working some slurry into it when I reach 800grit like with the small bug holes?
hmmm. Why is it cracking? Hard to say whether or not slurry will fix it or it will just reappear, best to understand why it might be cracking already
Forms are off but haven't done any sanding. I'm guessing its just a shrinkage crack! I used slightly less latex additive than I did on the first attempt that I cut out.
When did you remove the forms? The reason for the questions...I suspect that the slab should have stayed covered and dampened longer. For larger format stuff like your pour, depending on the temperatures, two weeks would be my minimum before I stripped the forms.
2 cracks!!! Neither appear to penetrate the slab completely. They're very fine cracks. Rather than try and work a slurry in, I'm going to run my angle grinder blade through it and then fill it. Hopefully this will avoid pockets of trapped moisture that might cause more damage when the frost hits it. Any reasons why this is a bad idea?
I wouldn't cut into the cracks. It will just weaken that spot further and it will continue to crack. Cracks are part of using concrete. As long as they're fine lines, don't worry about it. I have a couple cracks in my counters at corners/joints. I never even think about them
I would not worry about the cracks if they are small (read hairline) just make sure the counter is well sealed. In cold weather ice is the biggest enemy of concrete. You stop the water, there is no ice.
