Adhering red brick to metal
  • Adhering red brick to metal
    Folks;
    I would appreciate any suggestions regarding how I can "glue" fasten red bricks to the inside of a half of a 45 gallon drum. I would like to make a barrel oven and would like to have the drum on the outside to protect the red brick oven from the elements.
    Any help regarding this matter would be much appreciated.
    Wapiti
    Re: Adhering red brick to metal
    I don't really think that's going to be possible. Even though you might find something that will bond the two, heat and expansion might have other ideas.
    If I wanted to do this I'd design the barrel oven to fit underneath your drum. So your masonry would be structural and self supporting and the drum is really only a cover.
      Un-possible. The barrel vault will support itself, and you need to insulate between the two.
