Sorry . . . I did look at about 25 thermocouple questions for answers but have decided to confirm some things here.
I'm building a sort of experimental oven, the details of which I won't bother you with right now, so I do need some quick feedback on temperature as I am using gas jets in a sort of unusual way. Some of my need for the TC's is a learning experience to see if my heat transfer calculations are reasonable.
This is a very small oven which I am casting parts of myself. The deck will be made of a standard density 2800 degree F refractory cement and the dome will be an insulating, light weight commercial 2300 F refractory cement. I need quick temp feedback on the deck temp at perhaps 3 places, center, middle, outer (side to side, not top to bottom). I also want 3 locations to measure the dome temp, like center, mid and lateral.
I have extensive electrical experience with sensors and a little with TCs, so the electrical aspects shouldn't be a problem. I have read in other TC forum responses about different ways of placing the TCs in the material:
I'm thinking that a copper conduit (1/4" pipe for ex) might be a good option. But that leads to a related question of what form of TC assembly to use? Here are some varieties:
This page has some of the wire ones.
ThermoWorks Thermocouple Wire Probes
I sort of like the HIGH TEMP FLEXIBLE CERAMIC FIBER-INSULATED PROBE but it is relatively expensive. I guess that a metal conduit provides the best option for TC placement. That is, I could slide either a probe or wire pair down the conduit whereas with a drilled hole or bare hole I might have trouble threading the wire down the hole against rough cement. A conduit, particularly copper, could distort the temp but probably not by much.
One last question - are TC's ever just placed in the open space of the oven, say a couple inches from the dome (drilled through). Might be interesting to get a reading there as well, although open flame near by might distort the reading or damage the probe.
Regards . . .
- embed a probe in the material
- drill a hole after casting then place TC
- place a dowel or something to later remove to leave a tunnel for the TC
- Place a copper or other conduit into the castable material at the time of casting
- ceramic insulated wires terminating with the bare TC junction
- TC ungrounded probes of varying lengths (look like something you would stick in a turkey) some pointed, some flat. This includes about a 2" probe with a right angle that is used to measure exhaust gas temp up to 2300F
Regards . . .
