Can you build right on the vermiculite mix?
  • Can you build right on the vermiculite mix?
    I have built my base and hearth. The hearth is one half concrete (lower half) and the upper half is insulating concrete (vermiculite cement mix) My question is, do I build the oven right on top of the vermiculite mix with a layer of leveling clay? It doesn't seem to be real solid enough to tolerate the weight of the oven. I did this according to another site before I saw this one. The front part is full thickness concrete where the front of the oven would be, but the rest of the hearth is split 50/50. vermiculite on top of concrete where the actual oven would sit.
    Re: Can you build right on the vermiculite mix?
    How thick is the vermiculite/cement mixture and do you have an idea of the ratio you used in the mix?
    Tony
    Link to my oven build thread:
    40 inch indoor pompeii in NNY
      I plan a vermiculite 6:1:1 -- 3.75 in deep on a 3.75 in base slab
      Jim 48 ID PC Florida
        Both are 2.5 inches thick. Reinforced concrete and the vermiculite mix. The mix is 5-1 dry mixed and then a little water.
          If you have 4" of reinforced concrete under the vermicrete then you should be fine.
          Cheers ......... Steve
            Thanks Steve. I wrote 2.5" I meant 3.5" each. I split the depth of an 8" x 2" board on the sides of the form.
              You should be good to go with that. Good luck with your build. It is a rewarding project.
