Floor insulation
  • aary108
    • Oct 2013
    • 2
    Floor insulation
    Hi
    I have a pizza oven that someone else made and they used the ceramic blanket insulation under the firebricks, instead of the the FB cermaic board.
    Does anyone know what the real difference is between the two?
    Does one perform better than the other?
    I am noticing that the floor temp is around 720F degrees, and the pizza base is cooking ok but then inside the dough is slightly undercooked. So we have to leave it in longer
    This oven is a mobile setup that cooks many pizzas continuously. When there is a rush (cooking 20-30 pizzas an hour) the floor starts to lose its ability to cook the base all the way through. We would like to still try to cook them in about 2 minute intervals.
    Does anybody know if the the FB board would help?
    Basically we are trying to make this oven as efficient as possible, so any help would be much appreciated.
    Aaron
  • NCMan
    • Jan 2014
    • 846
    Re: Floor insulation
    I've not used the ceramic blanket, but my best guess is that it would compress under the weight of the oven and be quite inefficient in that capacity.
    My Build:
    • Laurentius
      • Nov 2010
      • 923
      Exactly what NCMAN said!
      • aary108
        • Oct 2013
        • 2
        Thankyou both for that confirmation. i will get some of the solid ceramic board and replace the blanket
        Regards
        • NCMan
          • Jan 2014
          • 846
          You're welcome. Best of luck w/it.
          My Build:
