Homemade pizza peel
  • George_M
    • Oct 2014
    • 290
    Homemade pizza peel
    Hi,
    I searched but i didn't find a topic related on construction of peels,either wood or aluminium.
    If someone made a peel,he can share here the method of construction,plans,etc.
    Regards,
    George
  • Les
    • Sep 2005
    • 2945
    Re: Homemade pizza peel
    George, I made my peels. I never took the time to document the process. I used .062 aluminum because it is really easy to cut with a jig saw. Post #192 shows a pic of the ones I use to slide the pizza into the oven. I built another with EMT pipe for the handle to remove them.
    • George_M
      • Oct 2014
      • 290
      I saw your peels,looks nice Les!
      Good job!
      I will search for al to make one
      Thanks!
        I think stainless is a better material than aluminium as it is more durable and less conductive. I've found the ideal thickness is 1.2 mm Regari g wooden peels solid timber is better than laminated which sometimes fail at the joins.
        • Les
          • Sep 2005
          • 2945
          David - it is a better material but it is a pain in the ass to cut at home. I've used my peels for 5 plus years w/ no problems. Aluminum is also way more obtainable for less dollars. JMO...
            Yes Les,
            that is true. I got mine laser cut and drilled, so I didn't do any of the work. These machines are becoming more common, your local school may have one.
            • George_M
              • Oct 2014
              • 290
              As for the size,which is good enough?
              Maybe 13" or more?
              • Wiley
                • Mar 2008
                • 804
                George_M,
                You might find some ideas on this thread:
                hope this helps,
                Wiley
                • George_M
                  • Oct 2014
                  • 290
                  Thanks Wiley,
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    hi les
                    I went to a sheet metal fabricator and picked up my stainless steel as much as unwanted for a $10 note from their scrap bin
                    Cheers Colin
                    Oven 1 Completed
                    Oven 1 and surrounds
