Hey guys,
So I just finished building my first pizza oven, and I am thrilled with it. As you can see in this photo there is a 2 inch thick concrete slab sitting on top of cinder blocks. On top of that is a fire brick arch dome. I did about 5 curing fires, of gradually increasing heat. I have used the oven twice for cooking; first time made only 2 pizzas and then the next time making 5. After making 5 pizzas, there was a noticable crack leading down a fire brick in the front into the slab. This is very worrisome as I thought the fire brick, with heat stop beneath it would prevent the slab from getting too hot. The slab is not made to withstand extreme heat. I patched it up with some repair cement, but I am afraid to use my oven again! And I was planning to have a party this weekend! Will a regular cement slab crack if it gets too hot?? I attached some photos of the crack as reference. It is hard to tell how deep the crack goes. Short of building a third cinder block leg for support, any suggestions for reinforcement? I do not want my slab to break in half and destroy the oven.
