Re: Saftey Issues
We may need to alert the mfrs is what you say is true, as the MSDS they put out with their product says otherwise, see below....
Eye Contact: Check for and remove any contact lenses. Do not use an eye ointment. Seek medical attention. If as you say they dissolve....why worry, nobody really uses their eyes anymore
Skin Contact: After contact with skin, wash immediately with plenty of water. Gently and thoroughly wash the contaminated skin with running water and non-abrasive soap. Be particularly careful to clean folds, crevices, creases and groin. Since the product can readily penetrate the protective epidermal layer and cause rashes or eczema, a good hand cream should be used after washing affected areas. Seek medical attention.If as you say they dissolve....why worry who need gonads anyway....
Serious Skin Contact: Wash with a disinfectant soap and cover the contaminated skin with an anti-bacterial cream. Seek medical attention.
Inhalation: Allow the victim to rest in a well ventilated area. Seek immediate medical attention. If as you say they dissolve....why worry skin is highly over rated
Serious Inhalation: Not available.
Ingestion: Do not induce vomiting. Loosen tight clothing such as a collar, tie, belt or waistband. If the victim is not breathing, perform mouth-to-mouth resuscitation. Seek immediate medical attention. Hmmm if they are so safe...why wouldn't a person be breathing
OK so we're talking about Calcium Silicate ( Ca2O4Si) basically two molocules of Calcium, bound to 4 molecules of Oxygen, and on molecule of Silica. Calcium does dissolve in the body and is essential for our metabolic functioning as is Oxygen. Silica....not so much, but as it's bound to the others and is a traveling companion when ingested either orally, through skin contact, or inhaled, in amounts that are different for every human being on this planet, based on their current health status or other environmental concerns. Remember asbestos was SAFE also until people started dying from exposure to it. BTW Asbestos is a set of six naturally occurring silicate minerals...I wonder if Asbestos has anything in common with Calcium Silicate.....besides the basic silica composition?
Particles of silica dust can be very fine and as small as one to six microns in diameter. We breathe and exhale them. Our lungs have scavenger cells called macrophages These cells dissolve dust particles by surrounding them. But if there is too much dust, an overload situation, the scavenger cells cannot completely clear the dust. Scarring is the lung?s reaction to dust which gets deposited in the air sacs. When there is a lot of scarring you can get shortness of breath.
YES it is and can be harmful people, WEAR A N95 DUST MASK AT THE VERY LEAST
Originally posted by jpar
View Post
