I know there has been a lot of discussion regarding thermal mass vs. heating time, but I had a thought last night as I was drifting off to sleep...would slightly more thermal mass at the apex of the dome provide for longer "stay hot" times without sacrificing too much in the way of rapid heat up? Here's my logic (such as it is when falling asleep after a night on call): the top of the oven seems to be the place where the oven goes clear first (makes sense - heat rises, and it is often in direct contact with the flame), and so would also be the place that starts to leech out heat into the insulating layer first. If more of this were captured by thermal mass (while the rest of the oven continues to go clear) might it not provide more reflective heat later?
I was thinking this could be done with either a slightly thicker level of refractory mortar at the top, or even mortaring small fragments to the outside of the dome at the apex (say the top 3 or 4 rows). Nothing that would compromise structural integrity.
Of course, the other argument is that the extra mass would be robbing the heat from the side walls which might be getting some of it via brick to brick contact).
I know Father McMahon (my HS Physics teacher) is rolling over in his grave right now.
