I'm sure this has been dicussed...
  • asudavew
    • Jul 2007
    • 1880
    But..
    Does it matter whether the floor bricks are set in mortar or dry set to the hearth?
    I was leaning toward mortaring them down and between gaps.
    My thread:
    My costs:
    My pics:
  • Les
    • Sep 2005
    • 2945
    Re: I'm sure this has been dicussed...
    Dave,
    The recommendation is a sand clay mix. Add a little water to make a paste and screed it off with a notched trowel. Don't worry about the gaps, it's my understanding that they will fill in with ash. I believe we want the floor to have the ability to "float". That's the approach that I have taken (but then again, I feel I'm outside the box and off the edge )
    Les...
    • rlf5
      • Jul 2007
      • 322
      I think either is fine. The main reason, so i'm told, for the sand/clay mix is to get the bricks level on the hearth. If its level enough for you then I say do without it. Thats the way I ended up going...bricks on isoboard.
      Oven Progress
      Bread Photos
      Oven Stand Thread
      • asudavew
        • Jul 2007
        • 1880
        Thanks guys.
        I wanted to just lay them and leave them, but the bricks, can we say, are imperfect. Highs lows, company stamps, etc.
        So i thought I would put a bit of mortar down to level em up.
        Nothing in between though? Ill go with it! But the edges are the worse part, rough, jagged and irregular. I thought they would be nice and square, perfect ... Ya know?
        But I guess that was just me dreaming!
        My thread:
        My costs:
        My pics:
        • Les
          • Sep 2005
          • 2945
          Dave, I had the dream as well. Use a belt sander - It really does wonders for the edges and level surface. If you wanted to spend many hours you could get it perfect, but it's about that pill thing...
          Les...
          • Dutchoven
            • Apr 2007
            • 931
            You can grind them or sand them to make them level. Shouldn't mortar them together though...God forbid one should crack...if the are just set in a firelcay sand mixture but nothing in between you could then replace an individual brick...otherwise much more difficult to replace...also won't get mortar in the food but rather some flyash which is just fine!
            Best
            Dutch
            • asudavew
              • Jul 2007
              • 1880
              Best
              Dutch
              Just a blend of fireclay and sand?
              No water?
              My thread:
              My costs:
              My pics:
              • Dutchoven
                • Apr 2007
                • 931
                I think it was one part clay one part sand and then mixed into a slurry with water, firm enough for it to hold the peaks when screeded with tile setters gauging trowel. Although some I have seen did it with the mix dry?
                Best
                Dutch
                • Ken524
                  • May 2007
                  • 1655
                  No water?
                  I used dry fire clay to level my floor. Sprinkled it where I needed a brick to be up a bit higher here and there. Then ground down the bad spots with a piece of scrap firebrick and hit a few other spots with my orbital sander and 60 grit paper.
                  Ken H. - Kentucky
                  42" Pompeii
                  • asudavew
                    • Jul 2007
                    • 1880
                    Thanks everyone!
                    I opted for a bit of sifted sand under the bricks that required it.
                    Seemed to work fine!
                    My thread:
                    My costs:
                    My pics:
                    • RTflorida
                      • Jan 2007
                      • 1446
                      I used an extra wet mix of Heatstop 50, very thin skim coat then gently tapped the bricks down into it - purely for leveling. The belt sander idea works very well at smoothing the installed floor bricks, use 40 grit for grinding down the uneven areas and then move up to 80 or 100 grit over the entire floor...you can make it smooth as a baby's ass in about 15 minutes. Just be sure to wear a good dust kask.
                      RT
                      • asudavew
                        • Jul 2007
                        • 1880
                        nOw i gotta dig out my belt sander...........
                        man this takes loads of tools.......
                        My thread:
                        My costs:
                        My pics:
