asudavew needs some advice..
  • asudavew
    • Jul 2007
    • 1880
    Ok..
    I've been thinking about how to finish my dome.
    I really want to keep the shape of the dome. But....... I don't want to coat it with perlcrete. I think the cement in the perlcrete lowers the perlite insulating value,.(it's the fluff and the air pockets that makes it such a good insulator.)
    So what I have been thinking of doing is building a dome-shaped wire cage around my oven. (I would leave about 6-8 inches between the cage and my dome.) Then covering the cage with aluminum screen, and finally filling the cage by pouring in the perlite through a hole in the top.
    Then I am going to place wire lathe around the screen for my stucco layers.
    Is this doable? Any reasons why this wouldn't work.
    I'd really like to know what everyone thinks.
    Thanks a bunch.
    Dave
    My thread:
    My costs:
    My pics:
  • Dutchoven
    • Apr 2007
    • 931
    Re: asudavew needs some advice..
    Sounds like a very logical way to accomplish what you are looking for
    Dutch
    • james
      Brick Oven Merchant
      • Mar 2005
      • 4648
      Hey Dave,
      That is definitely do-able and lots of people do it that way. As you say, you build a thin rebar and stucco lathe form around the oven, leaving room for insulation, then do the scratch coat and finish coats on top of that structure.
      Go for it!
      • Les
        • Sep 2005
        • 2945
        Dave, that's going to be my approach and it's in the plans - page 52.
        les...
          Make sure your outer enclosure is well sealed around the edges - loose perlite has a tendency to leak out. Otherwise, it sounds like a good plan.
          • asudavew
            • Jul 2007
            • 1880
            Thanks everyone!
            I was hoping for positive encouragement!
            I plan on starting this weekend. And I also need to make a door.
            So ... Dave will be busy on his oven again!
            My thread:
            My costs:
            My pics:
            • james
              Brick Oven Merchant
              • Mar 2005
              • 4648
              It's fun working on an oven where you have already cooked. You now get to mix soot with your mortar. It makes a nice greyish, black color, and it doesn't wash out of your shirt.
              Enjoy. :-)
              • dusty
                • Oct 2007
                • 575
                Very clever. Have you been staying awake thinking of this stuff?
