G'day people.
I need advice. (Probly medication as well,...[stuffit, there go all the Wise Ones]. Oh well, let's work with what we've got left shall we.
I'm a newbie to this brick oven game, but I'm just so hooked.
Seems to me that the opening is sealed when baking. Otherwise it remains open. Is this standard practice? Do some of you close off part of the entry when firing? How much and which bits do you cover?
Do you employ dampers in the chimney? If so, what type? Sliding? Butterfly? Rotating?
(I use a ss plate on top at the moment. Hahaha. Could do with refining. But then again as the Guru said: 'If it aint broke, don't fixit'. Man, I love that Guru so much!
Anyone using spiral-bent metal in the flue/chimney to increase gas velocity?
OK. So many questions in such little time. My next proposition was to be directed to the Old Salts. But I'm talking without listening.
I stop.
Jeff. (OK. The Luddite).
I stop.
