I'm a stong believer in keeping your concrete and masonry projects damp to allow it to "cure" and make sure it does not dry ( crack ). The other thing to remember is cement curing is an exothermic process giving off heat so you don't want to add heat too early to any oven/fireplace/chimney project.......and waiting to begin your curing fires is so hard to do
Here are two interesting excerpts from Wickipedia (and note the last line where it mentions that concrete is still curing and strengthening after over 70 years!) :
Curing is the process of keeping concrete under a specific environmental condition until hydration is relatively complete. Because the cement used in concrete requires time to fully hydrate before it acquires strength and hardness, concrete must be cured once it has been placed.
Good curing is typically considered to use a moist environment which promotes hydration, since increased hydration lowers permeability and increases strength, resulting in a higher quality material. Allowing the concrete surface to dry out excessively can result in tensile stresses, which the still-hydrating interior cannot withstand, causing the concrete to crack. Also, the amount of heat generated by the chemical process of hydration can be problematic for very large placements.
Allowing the concrete to freeze in cold climates before the curing is complete will interrupt the hydration process, reducing the concrete strength and leading to scaling and other damage or failure.
The effects of curing are primarily a function of specimen geometry, the permeability of the concrete, curing length, and curing history.
The second excerpt is about the Hoover Dam Project:
The first concrete was placed into the dam on June 6, 1933..... Since concrete heats up and contracts as it cures, uneven cooling and contraction of the concrete posed a serious problem....... The concrete is still curing and gaining in strength as time goes on.
It's really quite an interesting project.....
Hoover Dam - Wikipedia, the free encyclopedia
XJ
So while the waiting iis hard, the longer you can put off your first fires, the better it is for your oven/fireplace/chimney.....IMHO
XJ
