I am building a 36" oven and have poured the first layer of concrete for the base and now need to put in the insulation layer prior to the actual cooking floor. I have found a calcium silicate board that I could purchase (in NZ) but the cost of putting in 2 layers of 9mm board will exceed $200. My other option is preparing vermiculite concrete at a cost of $76 per 100 ltr bag ...... has anyone kept record of how much vermiculite will be needed for this part of the build?
How much vermiculite will I need to buy?
The short answer is, more than you think. The volume is decreased by around 20% of the dry volume of vermiculite because it compacts somewhat when wet and mixed. $76/100 L is expensive. Because you live on a volcanic island you might have access to pumice which is an alternative aggregate to vermiculite or perlite and could/should be way cheaper or even free if you know where to look. You may have to crush it down so there are no grains bigger than 6 mmI am building a 36" oven and have poured the first layer of concrete for the base and now need to put in the insulation layer prior to the actual cooking floor. I have found a calcium silicate board that I could purchase (in NZ) but the cost of putting in 2 layers of 9mm board will exceed $200. My other option is preparing vermiculite concrete at a cost of $76 per 100 ltr bag ...... has anyone kept record of how much vermiculite will be needed for this part of the build?Kindled with zeal and fired with passion.👍 1
