Reducing weight of stand and oven
  • kb8s
    • May 2016
    • 1
    I'm building an outdoor kitchen on an existing slab with a thickened edge on one side due to the slope. There's a good footing beneath. When I look at the material list for the project, it just seems like a lot of weight. I don't want the oven to cause one edge to compress more than the other.
    Besides the obvious, "Make the oven smaller", what are some things I can do to reduce the overall weight?
    I'm already looking at using pumice blocks. Would like other ideas to reduce weight.
  • RandyJ
    • May 2010
    • 1191
    You could have a steel stand built to hold the oven. Also if you are worried about the weight you could either buy a kit or cast your own oven. That would be a lot of weight savings. If you are not careful the weight can run away in a hurry. Last time I did a tally I believe I was over 16,000#. So you are wise to not put that on a existing slab if you are worried about it.
    Randy
    • oasiscdm
      • Jan 2012
      • 1239
      Hi
      Simple really do not use cement blocks. Do what I did and use Hebel Blocks [aerated autoclaved concrete] instead. should reduce weight substantially.
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
