After looking through all the ideas and not having any welding tools at hand, I came up with this variation.
A Couple of 24” Quick grips. Mount both sliders on the one bar. (on a good set they slide off to reverse)
Adjust the inside slider to the distance you want and it does not move again. Just move the outside clamp to grip the bricks as yon need.
I took the wheel off a spinning caster. Mounted the caster to the board that was covering and protecting the floor. A bolt and some spacers to attach to the clamp bar through the already present hole in the bar.
Voila!
The great thing is you have 2 very nice clamps at the end of the project.
Voila!
. I sorta missed that you already built your dome, so obviously your tool worked well and it was indeed a clever alternate design.
