chimney flow rate calculator
  • #31
    Updated spreadsheet
    Thanks Bruce. All of the credit is yours of course for having made the spreadsheet in the first place.
    Attached is a copy the corrects the math typo. If I screwed up anything in the process please point it out. And if you want to update your spreadsheet in the future, I'd be happy to delete this copy.
    • #32
      Re: chimney flow rate calculator
      Looks great. Thanks
      • #33
        That was very helpful with my duratech chimney project. Thanks!
        Looking for chimney liners in Canada.
        • #34
          Hello Mullins
          I made 2 blocks of Perlite/Cement to go under my entry columns. It was a 5:1 ratio and I was surprised how strong it appeared to be. The edges would crumble but it had good compressive strength.
          I went with FB because I did not want to gain too much height under the floor. I did consider using both Perlite/Cement and FB in combination.
          David
