When can I start sequential fires?
  • ubcpsyc
    • May 2018
    • 44
    The actual inner dome of my oven was done and has been dry for three weeks. This is the same for the layer of refractory concrete I covered the whole dome with to increase the thermal mass.
    two days ago I finally put on the ceramic blanket and the perlite mix.
    Yesterday I covered the whole mess with quikwall by quickcrete. I’m going to seal it today with acrylic concrete sealer.
    does anyone know how long I need to wait to start the fires? Really my only concern will be the quikwall covering but I can’t imagine that will see much heat with all that insulation!
    Thanks!
  • PsychDoc
    • Dec 2012
    • 76
    There may be an issue with steam escaping the sealed dome- I am no expert by any means. My thought is you may begin if you haven’t already. I have read that people installed a “vent” in the outer layer to allow moisture to escape. You could drill through to the blanket- it might even allow you to see the moisture vapor escaping. If not go Very slow.
    hopefully some of the resident experts will provide more information- good luc
      • 5259
      PsychDoc,
      This is a pretty old post.
      • fox
        • Mar 2017
        • 388
        Good answer though....
        • PsychDoc
          • Dec 2012
          • 76
          Well shut my mouth- I didn’t bother to check the date. Thought it was 2019
          UBCPSYC - you can definitely start the firing process
          fox- thanks for the feedback
