Arch too tall?
  • nickle
    • Sep 2018
    • 4
    Arch too tall?
    Everyone I think I may be slightly boned. And I need to help to determine how screwed over I am.
    I am building a 34 inch igloo style oven. I meant to do a 10 inch high arch, but screwed up and ended up with about a 12 in arch.
    I would really like to not have to pull out the arch and all pieces that attach to the arch.
    I am thinking right now to leave as is. But i'm not sure of how bad it will be when I do some cooking.
    What are the possible issues of having the arch too high?
    If it doesn't work, i'm thinking building a new half width arch, on the inside that mortars to the current arch.
    Any and all suggestions are welcomed.
    • 5259
    It is not the ideal ratio, but IMHO, since the arch is done is to leave as is. Currently you are at 70.5% vs suggested ratio of 63-65% but I have seen higher arch ratios as well. Move on.
    • wotavidone
      • May 2011
      • 800
      Assuming we are talking hemispheres and semicircles here, you've got a 12" arch and a 17" inside dome for 70.5% ratio. As long as it isn't ridiculously wide, I say leave it and move on.
      P.S. assuming you are doing a hemisphere your 34" dome will have a height of 17" inside. A 10 inch arch would have been 59%. A touch on the low side.
      • pizzaadmin
        • Sep 2018
        • 28
        Hi.
        Is it OK for 59% of 10 inch arch ??
        Please give me suitable suggestion for build up new arch ..
        • wotavidone
          • May 2011
          • 800
          would just go with what you've got. A photograph or two would help.
