Hey guys!
So I finished my inner refractory dome using the gym ball method. It worked relatively well, however one thing I've noticed is because I was mixing multiple refractory bags in a wheelbarrow several times, the mixture wasn't always 100% consistent. This caused certain layers to drop down slightly, overlapping the lower layers that had hardened. This means the inner done is uneven and at certain areas looks cracked. I'm thinking of adding a layer on the inside of the dome to even out the overlapping and fill in the cracks.
How would you recommend I go about doing this? Should I simply grind out the dome a bit to be even and then add a layer, or just add a layer on top of the overlapping?
