Wood roof
  • mazzazza
    • Sep 2018
    • 9
    Wood roof
    I'm planning on putting a wood framed roof on my oven, 100mm*50mm studs, covered with plywood/OSB with a fibreglass coating on top.
    I have a couple of inches of ceramic fiber blanket on top of the brick dome, then about 3 inches of vermicrete. Is this enough to stop any wood above catching fire?
    The closest part of the oven to the roof will be the chimney - single row insulating firebrick surrounding a stainless steel flue pipe.
    Any thoughts? The oven isn't close to the house so if the roof went on fire it wouldn't be life threatening but it'd be a bit of a pain in the ass!
    Any thoughts?
    Cheers,
    Chris
